1972 Ford Falcon
YELCOB
Electrical problem
1972 Ford Falcon V8 Two Wheel Drive Automatic
Hi i have just re fitted dizzy and need to know how set timing i wasent sure about year it is a351 cleveland
Nov 16, 2009 at 12:49 PM
  • 31,937 POSTS
Hi there,
Connect timing light to No 1 cylinder high tension lead and start engine , with vacuum removed & blocked, check the timing the marks are on the harmonic balancer and timing cover, set timing to 6 Deg BTDC @ idle choke off.
Mark (mhpautos)
Nov 16, 2009 at 1:02 PM
