bruce
wet weather ford
bruce
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the ignition system inspected under the conditions that reproduce the fault, including the cap and leads, before replacing the distributor pickup. Keep hands and tools away from live ignition components and moving parts.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
also run car in the dark to see if there are any signs of arcing around the wires and plugs
Discussion summary
wet weather ford
A 1980 Ford Fairmont 3.3L ran poorly in cold, damp weather but improved after warming up. The owner had already replaced ignition wires, distributor cap, plugs and module.
Reported outcome: No confirmed cause or repair outcome was reported.
Replies suggested cap damage and ignition arcing. The discussion does not confirm either, and the suggested petroleum-jelly and spray treatments are not included as verified repair guidance.
