1998 Ford Fairmont
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEBASTIAAN
Hi guys i really dont have any money but need some advice! my car is using a lot of water, exaust is wet, funny knocking sound in engine, waater in oil! what can be the problem and how do i fix it?
thank you
sebastiaan
Aug 29, 2008 at 5:26 PM
  • 31,937 POSTS
Hi there,
These are all the signs of a blown head gasket, a check of exhaust gasses in the cooling system will prove this, but i feel that the head will be the problem. The head will have to come off and be crack tested and surfaced at a minimum, when the head is off make sure that the block is spotless and that you replace the head bolts as well.
Mark (mhpautos)
Aug 29, 2008 at 5:58 PM
