Engine Mechanical problem
1997 Ford Fairmont 6 cyl Four Wheel Drive Manual 150k miles
I have low oil pressure after it warms up at idle, above idle its fine.
New oil pump. Is it possible to change out the rod and main bearings without removing the engine. Can I remove and replace the mains in the truck without removing the crank. Will the "roll" out
Apr 21, 2009 at 9:14 AM
