1995 Ford Fairmont crank shaft pully come apart
1995 FORD FAIRMONT
SUE_SUTTON
Engine Mechanical problem
1995 Ford Fairmont 6 cyl Two Wheel Drive Automatic
how do we do we get this back on
Nov 16, 2008 at 8:13 PM
  • 31,937 POSTS
Hi there ,
If the outer ring has separated, the pulley will have to be replaced, there is a special pulley tool require to do this job.
mark (mhpautos)
Nov 16, 2008 at 8:20 PM
DAVE H
  • 13,384 POSTS
if it's just the pulley that came off ?? because someone put it back loose ... then it just bolt's back on to the crankshaft .. if the bolt has sheared off .. you need to get the old bolt out .. this can be difficult depending on where the bolt sheared .. either way the pulley will eventually just bolt back in place and then you need to re-install drivebelt
Nov 16, 2008 at 8:45 PM
