Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fairmont
Brakes
Rotor
Replace/Remove
1995 Ford Fairmont
1995 FORD FAIRMONT
FORDNUT36
MEMBER
1 POST
Brakes problem
1995 Ford Fairmont V8 Automatic
how do i change the front rotor
Dec 27, 2008 at 12:03 PM
Experienced Mechanic
Hi there,
Just not sure if yous is the Aussie ford, so if not let me know, if it is, jack up car, remove wheel and un bolt caliper, lift clear and remove pads, remove dust cap, remove split pin and undo bearing nut, rotor will then come off spindle.
mark (mhpautos)
Dec 27, 2008 at 4:15 PM
Add image or video
Ask a new question
Engine won't start
Heater — Not Working
