1994 Ford Fairmont Problem with air bag indicator
1994 FORD FAIRMONT
SNAUC
1994 Ford Fairmont Automatic
Even after replacing 10amp fuse light still flashes wich indicates problem with air bag. In instruction manual just explains to see the Ford Dealer. No other suggestion. All started two days ago!
Can You Help?
Regards - Joseph
Jun 5, 2008 at 2:13 PM
  • 31,937 POSTS
Hi there,
There is an internal fault with the air bag you will have to get a scan done to identify the problem, the srs system will be in-op until it is repaired.
Mark (mhpautos)
Jun 5, 2008 at 3:39 PM
