1992 Ford Fairmont Doesnt Shift gears
1992 FORD FAIRMONT
PEPPI_CALO
Transmission problem
1992 Ford Fairmont 4 cyl Two Wheel Drive Automatic
hey i have '92 ford eb fairmont and there seemes to be a problem with the transmission when i have it in drive it doesnt seem to shift gears after the 1st gear. it you have your foot flat on the pedal it doesnt rev out and doesnt go to the next gear and it only stays on just under 2grand when you have your foot flat on the pedal. but once you have past 60km/h the grand then starts to move up. please help!
Jun 18, 2008 at 4:44 PM
  • 31,937 POSTS
Hi there,
If the fluid level is OK, i would be getting off to see a transmission specialist, you may be able to see if there is a transmission fault code set, but just about all repairs will have to be looked at by a qualified tech.
mark (mhpautos)
Jun 18, 2008 at 6:49 PM
