1991 Ford Fairmont
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALI1984
the problem is wen i use the blinkers all the dash light turn on and off and muck around and it will only go in reverse,1st gear and neutral??
wat is the problem??
Jun 3, 2008 at 7:35 PM
MASTERTECHTIM
  • 4,750 POSTS
a few problems, the problem with the lights is you installed the wrong bulb in the turn signal. very common, you installed, or someone installed a single filament bulb where there should be a 2 filament bulb. check the vacuum shift modulator on the side of the transmission for the shifting problem
Jun 3, 2008 at 11:27 PM
