1981 Ford Fairmont Starting
A.TREEPLANTER
Electrical problem
1981 Ford Fairmont 6 cyl Two Wheel Drive Automatic unkown miles
My car starts but won't run. As soon as I release the key after starting it, the car quits.
May 12, 2009 at 6:19 AM
HMAC300
  • 48,601 POSTS
check to see if you are getting power to the coil with the key on. If not you may have a bad connection at the bulkhead connector or ignition switch maybe bad.
Dec 17, 2009 at 10:59 AM
