1980 Ford Fairmont modulator valve
193,000 MILES • 6 CYL • 2WD • AUTOMATIC
UPS88
c4 transmission when changing modulator is there a small pin at the end of it & if so will it come out with the valve or will it run out with the oil or maybe just stay there in any case how do i keep from losing this i sure don`t wanna lose it
thanks
bruce
Mar 13, 2009 at 2:41 PM
HMAC300
  • 48,601 POSTS
it's a valve that goes in the valve body. As long as you are careful when you take the omofulator out it will be ok. Make sure your hose going to the modulator isn't cracked or leaking.
Oct 16, 2009 at 12:46 PM
