1978 Ford Fairmont Ignition Switch
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOOKSWORLD
My son's 1978 Ford Fairmonts key will no longer insert completely. I was trying to remove the ignition switch to replace it but I cannot remove without the key in the ignition. Any other method to remove and replace the ignition switch without the key being inserted?
Apr 13, 2009 at 9:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you tried a different key? The switch needs to be in LOCK to remove it successfully. Perhaps a visit to your local locksmith can help you out with turning the switch without a key, if a different key does not work.
Thanks for using 2CarPros.com!
Apr 13, 2009 at 9:20 AM
