1993 Ford Fairlane Car overheats when aircon turned on
1993 FORD FAIRLANE
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
WEEKENDWARRIOR
  • 6 POSTS
I have a 1993 Ford Fairlane Ghia 1993 NC model.
When I turn the aircon on in hot weather the car does not take long to overheat, needle up in the red zone very quickly.
I am unsure as to whether there is a thermostat in the car as I was told the previous owner took it out to achieve a full flow through of water in the aluminium block, could this be the problem with the aircon situation?
Regards,
John
Dec 12, 2008 at 4:12 PM
Check the AC condenser fan if its coming on when AC On. Also check the coolant level and replace the Stat and see what happens.
Dec 12, 2008 at 7:02 PM
WEEKENDWARRIOR
  • 6 POSTS
The AC condensor is mounted in front of the radiator, there is no fan on the condensor??
I will install a thermostat today.
Regards,
John
Dec 13, 2008 at 10:41 AM
WEEKENDWARRIOR
  • 6 POSTS
Installed the thermostat and has made some improvement with overheating however as soon as I hit stop start traffic the temp needle steadily heads towards the red zone.
Seems like the ac unit is operating as cold air coming out of it but engine is cooking!!????
Dec 17, 2008 at 3:04 PM
Get it block and pressure tested, water pump and radiator okay-
Dec 18, 2008 at 5:16 AM
