1992 Ford Fairlane Handbrake appears jammed
1992 FORD FAIRLANE
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
FREDLETED
As I was using my handbrake, it no longer racheted into the usual position. The handle becomes stiff & it is a struggled to unbrake.
Jun 27, 2010 at 11:15 AM
HMAC300
  • 48,601 POSTS
you can try lubing the cable as it's probably frozen in position. it may break loose. If not you 'll have to take the cable off , soak it in fuel oil for a few days, free it up and then reinstall it. It's the one that runs to the rear axle, not fun to take off but doable if you have time.....by the way it's a Parking brake not an emergency brake.
Aug 28, 2010 at 1:42 PM
FREDLETED
[quote:b0685975c2="hmac300"]you can try lubing the cable as it's probably frozen in position. it may break loose. If not you 'll have to take the cable off , soak it in fuel oil for a few days, free it up and then reinstall it. It's the one that runs to the rear axle, not fun to take off but doable if you have time.....by the way it's a Parking brake not an emergency brake.[/quote:b0685975c2]
Many thanks. I will have a look at the earliest opportunity. :-).
Aug 29, 2010 at 3:08 PM
