1966 Ford Fairlane water bypass tube
1966 FORD FAIRLANE
LIZELLA1
Engine Mechanical problem
1966 Ford Fairlane V8 Two Wheel Drive Automatic
how do you remove the water bypass tube from the intake manifold on a 390 c.u. engine?
thanks in advance,
melvin
Jul 7, 2009 at 10:08 AM
MIKE H R
  • 3,094 POSTS
you talking about the short one that goes from the intake manifold to the water pump? Only about three inches long? If so the best way is remove the clamps and put a slice in the hose. Then wiggle the hose off. msot time it is hard just to remove the hose and found that most times the hose is usually getting weak. Can get another hose at most auto stores.
Jul 23, 2009 at 3:30 AM
