1966 Ford Fairlane lights shuting off
1966 FORD FAIRLANE
180,000 MILES • V8 • 2WD • AUTOMATIC
FAIRLANE
well me and my friends were crusing around in my car and all the sudden out of no ware the high beams start flickering on and off and then the dash lights eventully everything seizes to work except the motor..soo we stop the car and shut it off for like 5 min and turn it back on and everything works ...but it deosnt do that often the last time it did this was way back in july soo my question is how do i fix this and yes this is a daily driver
Mar 16, 2009 at 2:22 AM
DOCFIXIT
  • 18,828 POSTS
Check out the pig tail ground from batt term to body
Mar 24, 2009 at 5:09 AM
MIKE H R
  • 3,094 POSTS
The pig tail in the engine compartment on the drivers side is dirty or correded. I bypassed the one on my 1962 and everything works fine. Most fuses are on the headlight switch. There is a singal one towards the dash on the switch that usually goes bad. It is hard to replace. If you are not keeping the car original you can rewire and install a fuse pannel like I did behind the vent , out of the way. I rewired it so everything went throught the fuses except the headlights. Convient to check and change fuses.
Jul 23, 2009 at 3:25 AM
