1965 Ford Fairlane Gas and Temp gauges
250,000 MILES • V8 • 2WD • AUTOMATIC
SLO96T
Can you give me some idea why my gas and temp gauges peg out when I turn on the headlamp switch? They appear to work fine until the wsitch is turned on.
Oct 6, 2009 at 5:57 AM
MIKE H R
  • 3,094 POSTS
there is a short, does it happen when you put on your parking lights? If so check the wiring in the trunk for pinched or broken wire. If not look under the dash on the right side and check the wires going to the constant voltage regulator. See if there is a burnt wire or frail wire.
Oct 14, 2009 at 6:10 AM
