1963 Ford Fairlane Engine Swap
1963 FORD FAIRLANE
98,972 MILES • 6 CYL • 2WD • MANUAL
FLYING JESTER
I'm putting a 1964 Ford 292 V8 from an F-100 into my 1963 Ford Fairlane (standard, not 500). I need some motor mounts, but none exist to do this particular swap as the midsize Fairlane was never equipped with this type of engine. What Y-Block equipped car's motor mounts do you think would be the best to adapt for this swap? (And I am sure I want to do this swap. 100 percent sure.)
Jan 19, 2010 at 10:04 AM
HMAC300
  • 48,601 POSTS
there are no mounts for this type of switch, you would have to make your own. If it had a 260 in it a289 will bolt right in in place of the other motor including the transmission. Your 292 will not do this however. Besides the 260/289 or actually 302/351 are a much better engines.
Feb 28, 2010 at 11:19 AM
