1995 Ford F-450 Antifreeze
1995 FORD F-450
15,500 MILES • 6 CYL • 4WD • AUTOMATIC
SBL123
What are the probable causes of a leak of antifreeze? I fill the resevoir and within a week it's empty. I'm pretty sure the resevoir is ok. What else could it be?
Jun 11, 2010 at 11:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
busted engine block, cracked head gasket and/or head, faulty radiator hose(s), failing water pump, busted radiator etc.... check engine oil to see if it looks like coolant is mixing into it. also check for visible signs of leaks i.e. smoking out exhaust or wet spots in engine compartment.
Jun 11, 2010 at 12:41 PM
