spitting and sputtering all rpm ranges
SISSYPOO1
  • 5 POSTS
i have a 93 mercury villager when accel it spits and spudders cked all sensors for proper restence ok cked fuel presure ok could it be that the dis. not advacing properly because it does it all the time how would i ck to see if computer is working properly advancing the dis.properly also it seems to clear up and run ok about 3500 rpm if you try to step on pedal it spitts an spudders then all of a suden it takes off or some times it will just dye off and start to slow down and wont re cover until you stop and go again please help
Jan 22, 2006 at 1:17 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify what work was performed on the mass-airflow sensor and whether the reported improvement continued.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
Mass Airflow Meter?
Jan 24, 2006 at 8:24 AM
SISSYPOO1
  • 5 POSTS
thank you the mas air flow sensor fixed problem also had a dirty injector cleaned and runs fine now lots of power
Feb 3, 2006 at 7:56 PM
Discussion summary
The owner of a 1993 Mercury Villager reported sputtering and hesitation during acceleration, sometimes followed by a return of power. The owner described sensor and fuel-pressure checks as satisfactory. In a follow-up, they reported that a mass-airflow sensor fix and cleaning a dirty injector resolved the problem.
Reported outcome: The owner reported that the vehicle ran well with restored power after the mass-airflow sensor fix and injector cleaning.
The exact sensor work was not described. Because both actions were reported, the thread does not establish that either alone resolved all symptoms. No longer-term follow-up was supplied.
Read the original discussion
