shakey steering wheel
BIGCOUNTRY625
  • 8 POSTS
i have a 1994 ford e-350 460cid.the symptoms i am have is a very shakey steering wheel at various speeds,or if i hit a bump it will start to shake.but will stop on its on or if i slow down a bit will stop it temporarly but will soon return.thanks for your help
Feb 4, 2007 at 9:35 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
check suspension and steering for worn bushings, and loose connections, if found tighten or replace. (preferably replace for safety reasons)
Feb 4, 2007 at 10:31 AM
SERVICE WRITER
  • 9,123 POSTS
Yeah, I see Knight's view too. check ball joint, tie rods and wheel bearing play for starters.
Feb 4, 2007 at 11:17 AM
