How do I bleed water from fuel
FORD F-350
KAMAKEAHALE1
I was recently left alone for at least the next 4 months and my husband left me the truck. the truck is a 1995, F-350 Diesel 1 ton with a 7.3 motor I think.
The water in fuel light keeps comming on and I know I have to bleed the water from the fuel but do not know where or how to do this. Can someone help please.
Sep 10, 2007 at 2:50 AM
CHEVYTRUCKIN365
  • 11 POSTS
Best thing to do is look under truck ,Check to see if you are a lucky one with drain or drains on fuel tanks ...
Probably not, If your feelin froggy you can try to lower tanks with you and another person dump fuel and put in new .............................................
Or you might just get LUCKY with getting a fluid transfer pump or Jiggler Pump and siphon gas tank 's
Be sure to have new fresh fuel on hand
FolkLore is If gas station is with in 1.5 years of being new do not buy fuel because under ground fuel tanks have not yet acclimated to temp in ground and form condensation in fuel !!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 at 7:21 PM
SERVICE WRITER
  • 9,123 POSTS
Information sent, Will update later.
Sep 12, 2007 at 1:07 AM
