Fan Clutch
RICKC
1990 Ford e350 van. Engine Overheating. Replaced thermostat. Hoses are good, no leaks, water pump okay. No water in oil, no steam at exhaust. When engine overheats, radiator is overpressurized. Replace radiator cap? Could fan clutch not be engaging? How is this checked?
Jul 22, 2006 at 7:06 AM
TAURUSWHEEL
  • 718 POSTS
Does it have an electric fan??? I'm not too familiar with trucks?? If the fan is not kicking on, it'll overheat... does it happen only in traffic?? or even on the highway??? How do you know the system is overpressurized?? Remember, overheating is one of the worst thing that can happen to a motor.
Jul 23, 2006 at 3:28 AM
MIKEYBDMAN
  • 623 POSTS
[quote:6083818ab0="RickC"]1990 Ford e350 van. Engine Overheating. Replaced thermostat. Hoses are good, no leaks, water pump okay. No water in oil, no steam at exhaust. When engine overheats, radiator is overpressurized. Replace radiator cap? Could fan clutch not be engaging? How is this checked?[/quote:6083818ab0]
Usually when the clutches go bad, they freeze up and the fan turns the speed of the egnine. Load roar when the engine turns up speed. U should be able to see if the fan is turning by running the engine and pulsing the throttle. You can tell if the fan is increasing speed.
It almost sounds like you have an obstruction blocking flow in your system. Nobody has ever put any stop leak in the radiator have they? I know that stuff has been known to clogged the orifices in the head gasket. This in turn increases cylinder head temp, and eventually will create more heat than the system can take.
How does your radiator fluid look? Is it brown with floaty thingys in it? If this is the original engine, it may be time for a top end job. Give you a good chance to remove the heads and have access to all of the cooling system.
Im not saying tear your engine apart, but atleast do a compression check and make sure you dont have something going on with the heads.
Good luck, and let us know what fixes the overheating problem.
Jul 23, 2006 at 11:13 AM
EDWARDALLENBAILEY
I just had the same problem.. i had a clogged radiator and the overheating caused my coolant temp sensor to go as well. I replaced the radiator flushed the whole coolant system and replaced the sensor
Apr 4, 2009 at 2:19 PM
