a/c blowing out defroster vents only
PAMELA2265
i have a 2004 F350 diesel ford truck. the a/c this morning is only blowing out the defroster vent. actually the front vents are not working at all. i checked all fuses and everythings o.k., is there something else i can do myself to fix this.
Jul 9, 2007 at 2:49 AM
SARGEHAH
Check the electrical connector on the vacuum pump under the hood, I had the same probelm not long ago and all that happened is that the electrical connector had worked itself loose from the vacuum pump. I dont know if this would be your problem too or not but it is worth a try.
Jul 20, 2007 at 7:09 AM
CHEVYTRUCKIN365
  • 11 POSTS
Try and check for vacume under hood passenger side next to Evap coil you'll see a white vacume tube going to a cylindrical canister wich operates a door for heater or evaporator if so look under dash for
another canister like the one outside just a little flatter should be the one on the passenger side you may have take out remove hose carefully with truck running you should hear a sucking noise try in all setting's to make sure you got the right one
remove (vac canister) put your mouth on tube should have resistance and arm should move
Let me know if this Help if not i got a couple other things for you to try
Sep 10, 2007 at 4:50 PM
