2008 Ford F350
2008 FORD F-350
28,000 MILES • V8 • 4WD • AUTOMATIC
HOGANMAN
My name is dave
I have a 6.4 liter diesel that i need help with.
Here is the problem:
When i run my truck and shut it off or just turn key on and then back off the power keeps feeding the turbo charger actuator, egr valve actuator, and egr throttle plate valve. Only way to shut it off is to disconnect the battery cables and they stay off until key is turned on again. Unplugging individually and plugging them back in they still hum and have power to them.When scanning i got code p132b turbo charger boost control A performer. Did test and it tested ok. Code p1335 egr valve plate postion sensor min performer tested ok. Code p042e egr actuator stuck open. I replaced it with a new one but hte problem is still there. Also replaced pcm. Problem is still there. I need help
Oct 11, 2009 at 10:40 AM
SERVICE WRITER
  • 9,123 POSTS
I apologize for not reading too carefully but this is under the factory warranty. Shouldn't cost you a dime or a worry.
Oct 11, 2009 at 6:06 PM
HOGANMAN
[I would have brought it to dealer if it had warranty.This engine came from a wrecker.As stated i have done the diagnostics. Could you please answer the question instead of looking for the easy way out.Or siply refund me the money!!!
quote="Service Writer"]I apologize for not reading too carefully but this is under the factory warranty. Shouldn't cost you a dime or a worry.[/quote]
Oct 11, 2009 at 7:51 PM
SERVICE WRITER
  • 9,123 POSTS
I was trying to save you money. Did I really deserve negative feedback for that? DO you think I really want to help you at this point?
Oct 12, 2009 at 6:49 AM
HOGANMAN
My appologies, in all my frustration to seek expert advide I neglected to state that I have no warranty. Leading you to beielve that option was available to me. Sorry for the feedback,your response seemed like i was sent down the garden path, like so many before you the "try this try that" method left me with no results. Any advice you can offer would be rgeatly appreciated.
Oct 12, 2009 at 12:37 PM
