rear driver side brake sticking
80,800 MILES • V8 • 4WD • AUTOMATIC
F350JIM
I have a problem. The driver side rear disc caliper I cant remove can you help?
Aug 27, 2010 at 3:06 AM
DANNY L
  • 5,648 POSTS
Here is the information you requested. Here is a tutorial on how to remove and replace rear brake pads and rotors: This video shows the job being done on a similar car but the process is the same.
https://youtu.be/EMxfb9X3ywE
and
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
I've attached picture steps below on how to replace the brake pads on your truck. Hope this helps and thanks for using 2CarPros.
Mar 12, 2021 at 1:01 PM
