2006 Ford F350 power steering pump
85,000 MILES • V8 • 4WD • AUTOMATIC
LOUIE08
2006 ford diesel dually 4X4 i recently replaced the power steering pump due to noise it was making.i replaced it with a reman noise kept happening so i replaced it with an OEM pump and noise is still there.what else can it be that would be making that noise.resovoir is full and noise does not happen when belt is removed the noise is constant and will speed up if you accelerate.
Jul 1, 2010 at 11:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be the belt is not tight enough or tensioner for belt is not working. are you certain it is from the pump? may be from the rack ?
Jul 1, 2010 at 12:02 PM
