2006 Ford F350
58,600 MILES • V8 • 2WD • AUTOMATIC
CHRISGADDIS
I have recently installed a new radio. During the process, I ran the battery down and had to charge the batter before starting the vehicle. Everything seems fine except that the A/C is now blowing hot air. The digital readout is also wrong when you ask for the ext. temp. What should I check?
Aug 30, 2008 at 1:34 PM
BMRFIXIT
  • 19,053 POSTS
Since the radio sits in the area and above the HVAC controls
as a 1st step I would check fuses then recheck the work u did
making sure nothing was left disconnected or got disconnected
good luck
Aug 30, 2008 at 11:36 PM
