Stereo wiring
2005 FORD F-350
61,000 MILES • V8 • 4WD • AUTOMATIC
ATCONTROLR
I'm installing an after market stereo - Pioneer AVIC-X920BTS and I have two wires to hook up and I don't know where to find the source to hook them up to. One is a speed signal input (for GPS accuracy) and the other is the reverse gear signal input. Can anyone help me here?
Mark
Jul 21, 2010 at 6:33 AM
KHLOW2008
  • 41,814 POSTS
Hi atcontrolr, Thank you for the donation. The speed signal is to be attache to the Speed Sensor Assy wiring whereas the back-up can be spliced at the reverse switch or its wiring.
https://images.2carpros.com/forum/automotive_pictures/192750_SensorTrans05F350Fig17_1.jpg
What is your engine capacity?
Jul 21, 2010 at 7:31 AM
ATCONTROLR
I have a 2005 Ford F-350, crew cab, long bed, 6.0L diesel. Where can I conveniently tap into the speed signal, reverse gear signal, and parking brake power supply side
Jul 21, 2010 at 12:47 PM
KHLOW2008
  • 41,814 POSTS
For diesel the system is different. The VSS is supplied by the ABS module. You either tap it from PCM Pin # 35 or ABS module Pin # 21 (Gray/Black wire).
https://images.2carpros.com/forum/automotive_pictures/192750_PinPCM05F350Fig40a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_PinPCM05F350Fig40b_1.jpg
. For reverse signal, you can tap it from terminal # 2 of the reverse lamp relay, in central junction box, behind left side of dash. There are 2 wires going into the parking brake sensor. The wire you need to tap in to should be green with a red stripe
Jul 21, 2010 at 11:54 PM
COMGLE64
I have been having a problem with dead batteries. I narrowed it down to fuse 11 which is the radio. Whit the fuse out there is no draw, if i unplug the radio and leave the fuse in there is no draw. What could be causing my radio to draw power when off. It is the factory unit.
Mar 13, 2019 at 10:48 AM (Merged)
JDL
  • 16,098 POSTS
The radio memory and clock, where applicable, need some voltage even with everything turned off. Can you check the actual amp draw?
COMGLE64
With the test light hooked up the light was kinda pulsating. How do i test the amp draw. I have a multimeter.
JDL
  • 16,098 POSTS
If the meter has an amp setting, your in business. use the amp setting, place the meter in series with one of the battery cables.
BOOMER1121
I removed my radio from my Ford F350 and when I put it back in nothing works on it I have changed the fuse and checked the wires and cannot figure out what it could be.
  • 31,937 POSTS
Is it a security system radio? you may need to re code this with the correct security PIN.
mark (mhpautos)
BOOMER1121
Do you have any clue what the security PIN might be? or how I would go upon finding it?
Mar 13, 2019 at 10:49 AM (Merged)
  • 31,937 POSTS
if it is not in your owners manual or radio hand book, you will have to contact your dealer with the VIN they should be able to get it off the master data base for you.
mark (mhpautos)
