2004 Ford F350 Leak in front engine seal
128,000 MILES • V8 • 4WD • AUTOMATIC
ANTWONRAMSES
Do you need to remove the engine to replace the front engine seal?
May 27, 2009 at 10:00 AM
2CARPRO JACK
  • 11,533 POSTS
No, bu tyou will need to remove the fan and fan shroud, most likely the radiator.You will also need some kind of an impact gun to get the front crank bolt out, then a puller to remove the crank pulley
May 28, 2009 at 12:48 AM
