2004 Ford F350 Getting Multiple Codes & Tow Light Flash
56,000 MILES • V8 • 4WD • AUTOMATIC
JPOPEJOY
Hello, about 6-8 months ago ( 1000-2000 ) miles ago my truck started having slipping issues but the the fluid was great. So i drove the truck as minmal as possible and over time it got worse. So I had the codes read and it was a output speed sensor it says. So I changed that. And within the first day the truck still ran really bad slipping and hard shifting and than the tow haul light started flashing and the truck is even worse were now it has no nuetral or reverse and wont shift past second gear, which befor i could still drive on the freeway at 65. So now the OSS is not on the codes but now I get alot of different ones as in: P0700, p0751, p0756, p0761, p0766, p2700, p2701, p2702, p2703, p1705. I believe those are the TCM codes and the PCM codes I am getting are as follows, P1703, P0261, p0264, p0267, p0270, p0273, p0276, p0279, p0282, p0603, p0611, B1355, B1359.
Oh i need help please!!!!
Jerod
Sep 22, 2008 at 10:39 AM
BMRFIXIT
  • 19,053 POSTS
Way toooooo many codes
if that a truck I am about to work at
this is what I would do
record every thing down
disconnect the battery for a min or two reconnect and check for codes
start and check for codes
drive and check for codes
then deal what I have for codes as they appear
of course always start by checking fuses and wiring and connectors
check for any missing fuses very easy to over look
good luck
Sep 22, 2008 at 11:00 AM
JPOPEJOY
Ok well i deleted all my codes and started fresh and now the only codes i am getting is p0700, p0756, p0761, p0766 and p2701, p2702, p2703 can you please tell me what this will might be if a sensor or something maybe or what else I can do to try and narrow it down some more. Thanks, Jerod
Oct 5, 2008 at 12:28 PM
BMRFIXIT
  • 19,053 POSTS
ITS ALL RELATED TO A TRANNY ISSUE
friction plates
have the tranny check
Oct 5, 2008 at 1:04 PM
JPOPEJOY
Ok how do i test the shift sloenoids? That is my problem I have one stuck so now I need to find out how to test them. Please let me know thanks.
Jerod
Oct 7, 2008 at 6:42 AM
