2004 Ford F350 4 wheel drive
75,000 MILES • V8 • 4WD • AUTOMATIC
DBLSKUNK
when I put the truck in 4wd it does not engage the front wheels on "hi" or "low"
Dec 13, 2009 at 10:10 PM
TODD35
you need to find out if the drive shaft is turning when you engage 4 wheel. it could be the vacum pump under the hood or the vacum lines to the front hubs. 'the rubber lines that are next to the brake lines'' or it could be the shift motor on the transfer. if you put it in low range you shoud hear the gears in the transfer move. if not the motor is probibly not working if you hear it move try turning the lockout on the front axles'' by the tires on both sides'' see if that works. if the lockouts work it is a vacum leak. if none of this works by a dodge
Dec 19, 2009 at 5:46 AM
