2003 Ford F350 instrument cluster
193,363 MILES • V8 • 2WD • AUTOMATIC
TINYTURBO
my trucks instrument cluster went out,the truck won't start,but tries,it clicks,but you can jump start it. The pto is also out. I repair the wire of the od which had a rub through ,checked all the fuses and still no start. I really need help
Sep 11, 2010 at 9:18 AM
TECH1FORD
  • 102 POSTS
If it tries but just clicks I would suggest that you get the batteries tested, the clusters on these trucks need power to run, but if you can jump start it, does the cluster come back when running. if it doesn't needs an alternator also.
Sep 22, 2010 at 9:39 AM
