2003 Ford F350 Door Sensor Light
229,000 MILES • V8 • 4WD • AUTOMATIC
JIMNLYNN
This is a Crew cab diesel. The door ajar light on the dash keeps coming on even when the doors are closed. Is there a sensor in there?? How do I check I cannot see anything like the push button sensors.
Apr 15, 2009 at 4:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Door ajar switches are located inside of each door panel. This is a vary common issue with the newer model Ford truck and SUV line up. I am not sure why they haven't made this a recall but it is not. You will have to inspect each switch to locate the faulty one.
Thanks for using 2CarPros.com!
Apr 15, 2009 at 4:34 AM
JIMNLYNN
Thanks BlueLight... Where are these located?? Do I need to pull the interior door panel off. I appreciate the help.
Apr 15, 2009 at 7:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, they are inside the door panel so it must first be removed to gain access to them.
Apr 15, 2009 at 9:06 AM
