2002 Ford F350 vibration
2002 FORD F-350
125,000 MILES • V8 • 4WD • AUTOMATIC
JAMES-123
felt a vib. when braking was told that the rotars are warped on the front i put new rotars and pads on and i still can feel a vib when braking at 15 - 10 mph seams to feel like it is on the drivers side could it be the back rotars as well and i am feeling them in the pedal?
Apr 21, 2010 at 3:51 AM
AUTOZONEBRAKESEXPERT
  • 47 POSTS
If your pedal pulsates when you apply the brakes:
* Pedal pulsation is caused by excessive run-out in the rotors or drums that are out of round. These conditions occur due to excessive heat.
* It is important to differentiate a warped rotor condition from ABS operation. When the ABS kicks in the driver may experience pulsation in the brake pedal. This could be confused with a warped rotor.
Apr 10, 2011 at 2:02 AM
