2002 Ford F350 glow plugs
2002 FORD F-350
125,000 MILES • V8 • 4WD • AUTOMATIC
RALGER0110
Hi, my glow plug light won't turn off and at the same time the injector drive module relay is continually clicking
May 31, 2010 at 8:44 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you may have an IDM that has gone bad.I would start with a computer scan to see if the PCM has stored any codes pertaining to the IDM.Check all fuses too, inside the cab and in the underhood fuse/relay center.
Jun 3, 2010 at 9:06 AM
