2002 Ford F350 Door indicator light will not go off
JJAMES011958
  • 2002 FORD F-350
  • V8
  • 160,000 MILES
Can someone tell me what causing the problem with my door indicator light, it will not go off. It continue to buze all the time.
Saturday, December 20th, 2008 AT 4:17 PM
DAVE H
  • 13,384 POSTS
Check the switch and wiring to the switch on the door pillar near where the hinges are located on drivers/passenger doors?
Saturday, December 20th, 2008 AT 4:50 PM
1MGCMN
Try unloading a can of WD-40 in the latch on the door. There are pin switches in these latches that get sticky. It may be necessary to remove the inner door panel to gain better access. This is a very common problem w/ fords.
Greg
Sunday, December 21st, 2008 AT 5:54 AM
