2002 Ford F350 Door ajar
2002 FORD F-350
65,000 MILES • V8 • 4WD • AUTOMATIC
MT660R
I HAVE BEEN HAVING A PROBLEM WITH MY F350 AND DOOR SWITCHES. i HAVE SPRAYED THEM WITH WD-40 MANY TIMES AND THAT HASENT SOLVED THE PROBLEM. HOW DO i DIAGNOSE WHICH DOOR IT MAY BE? COULD IT BE SOMETHING OTHER THAN A DOOR SWITCH? I HAVE TAKEN THE DOOR PANELS OFF BUT I COULDNT FIGURE OUT HOW TO GET THE SENSOR TO RELEASE OUT OT IT SOCKET. THANKS IN ADVANCE FOR YOUR HELP.
Jan 26, 2008 at 6:12 AM
BMRFIXIT
  • 19,053 POSTS
[quote:ac4295c842="mt660r"]Electrical problem
2002 Ford F350 V8 Four Wheel Drive Automatic 65000 miles
I HAVE BEEN HAVING A PROBLEM WITH MY F350 AND DOOR SWITCHES. i HAVE SPRAYED THEM WITH WD-40 MANY TIMES AND THAT HASENT SOLVED THE PROBLEM. HOW DO i DIAGNOSE WHICH DOOR IT MAY BE? COULD IT BE SOMETHING OTHER THAN A DOOR SWITCH? I HAVE TAKEN THE DOOR PANELS OFF BUT I COULDNT FIGURE OUT HOW TO GET THE SENSOR TO RELEASE OUT OT IT SOCKET. THANKS IN ADVANCE FOR YOUR HELP.[/quote:ac4295c842]
Most likely its the driver door
but you can scan the body control module data that will show witch switch is staying open
good luck
Jan 26, 2008 at 7:19 AM
MT660R
Do I need to take it to the dealer to have the body control module scan performed?
Jan 26, 2008 at 8:26 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4bd09cc5f4="mt660r"]Do I need to take it to the dealer to have the body control module scan performed?[/quote:4bd09cc5f4]
i dont think so
any shop with a good scanner can do it for you
someshops do it for free and others may charge you $30-$40
Jan 26, 2008 at 11:51 AM
