2002 Ford F-350 Brakes
ROBERT LEWIS
Brakes problem
2002 Ford F-350 Four Wheel Drive Manual 186000 miles
On my ford f-350 few mths back i noticed a pulse in the pedal when sitting at a light that went away now sometimes if i hit the pedal hard i have brakes and sometimes i don't other times the pedal goes to floor if i pulling up to a light sometimes if i keep the same pressure on the pedal its fine but if i let up just a little the pedal goes to the floor lose all pressure. this is a 7.3 turbo
Oct 5, 2010 at 2:20 PM
TECH1FORD
  • 102 POSTS
it is your master cylinder that has failed the pulsing in the pedal is felt from the power steering system which also runs the brake assist, really common on a super duty
Oct 9, 2010 at 4:13 PM
