2001 Ford F350 leaking transmission
108,000 MILES • V8 • 4WD • AUTOMATIC
RBLACK19
I was backiing my boat in the yard the other day and noticed i was leaking some tranny fluid at the flywheel dustcover. It isn't a constant flow but I am concerned any suggest?
Apr 21, 2008 at 1:00 PM
FLEXY5
  • 512 POSTS
It is the torque converter seal. It's pretty common for them to leak. It is possible for just the seal to be replaced, but quite often the converter hub is grooved and should also be replaced.
Apr 21, 2008 at 3:00 PM
