2001 Ford F350 Engine idles while accelerator pedal is depr
TEDSFORD
  • 2001 FORD F-350
  • V8
  • 150,000 MILES
While in a stand still mode the engine idles as normal: however when the accelerator is depressed there is no effect on the rpm of the engine. This is an intermitting proplem. Occurs only rarely, and after three-four accelerator depressions the problem goes away.
Tuesday, April 6th, 2010 AT 1:20 PM
Hi tedsford, Welcome to 2carpros and TY for the donation
Check and test the throttle position and clean out the MAf sensor with an approved cleaner.
Tuesday, April 6th, 2010 AT 2:11 PM
TEDSFORD
Where are the throttle and sensor located on my 7.3L deisel
Tuesday, April 6th, 2010 AT 3:42 PM
Disregard the MAF sensor it doesn't have one-Check and test the Accelerator pedal position sensor located under left side of dash above brake pedal
Tuesday, April 6th, 2010 AT 5:15 PM
