2001 Ford F350 code po357 ignition coil 7/g primary/seconda
PLAYGOLFWITHJIM
Computer problem
2001 Ford F350 Four Wheel Drive Automatic 106500 miles
I have a code po357 on my 2001 ford f350 v-10 gas engine. any Ideas on what it means or maybe if its a coil and if so which one? thanks jim
Feb 6, 2008 at 6:55 AM
JRADIVO
My book says it is Ignition coil no. 7 primary circuit fault. Replace ignition coil 7, which is 2nd back on drivers side from front, which an ignition coil is mounted on top of each spark plug. Found answer in Haynes Repair Manual.
Feb 6, 2008 at 11:01 AM
