2000 Ford F350 Starting
DARRELL.CARRUTHERS
  • 2000 FORD F-350
  • V8
  • 4WD
  • 329,000 MILES
Are these trucks hard starting or if your voltage is down a little will it not start? It cranks good but would not start.7.3 diesel?
Wednesday, July 21st, 2010 AT 11:58 AM
JAMES.HARGIS
  • 9 POSTS
Check volt and amp one the batteries while disconnected. The recommended CCA ( Cold cranking Amps) is 875 each. Less than 600 you have battery problems. Voltage should be 12 each less then 11 volts and either you need a charge or they are bad.
Tuesday, July 27th, 2010 AT 3:28 PM
