2000 Ford F350 missing
DKG205
Engine Performance problem
2000 Ford F350 Four Wheel Drive Automatic
2000 f350 v10 missing bad .changed gas filter no help
Feb 21, 2009 at 7:31 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Feb 21, 2009 at 7:38 AM
