2000 Ford F350 Mass Air Flow Sensor
F350MUDDER
Engine Performance problem
2000 Ford F350 Four Wheel Drive Automatic 98,178 miles
I tried to get my truck smogged and the codes P0171 & P0174 came,I know its a system to lean in bank 1 & 2. I changed my fuel filter and I noticed that there was a big hole on the bottom of my air intake hose,would that cause those codes to come up.Thanks in advance.
Aug 19, 2010 at 9:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is it a man made hole or you mean a busted hole? it could be where a sensor should be such as the intake air temperature (IAT) sensor.. if it is missing that would definitely cause these issues.
Aug 19, 2010 at 9:55 AM
F350MUDDER
Its not man made nor was there a sensor there,I think its just wear and tear plus some heat,I put a new one on and now I bought some mass air flow sensor cleaner,but I don't know where its at.
Aug 19, 2010 at 9:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the MAF sensor is in the left front of the engine compartment
Aug 19, 2010 at 7:02 PM
