2000 Ford F350 diesel f350 truck
2000 FORD F-350
ALEXFERNANDEZ17
Engine Mechanical problem
2000 Ford F350 V8 Two Wheel Drive Manual
when turned on the engine sounds like it has a lot of power but when you go out on the road the engine starts to fail and it stops to run we have replaced the fuel pump that goes in electrical chases and the problem is still the same we think that it only happens when when it is hot because when it cools it works fine
Mar 28, 2010 at 10:33 PM
MERLIN2021
  • 17,250 POSTS
Has the cam sensor recall been done on this one?
SAFETY RECALL 07S57 - 7.3L DIESEL ENGINE - CAMSHAFT POSITION (CMP) S...Page 1 of 16
SAFETY RECALL 07S57 - 7.3L DIESEL ENGINE - CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT SERVICE CAMPAIGN BULLETIN Reference Number(s): 07S57, Date of Issue:  December 4, 2007 FORD:1997-2003 F-Super Duty, Excursion, E-Series Related Ref Number(s): 07S57
ARTICLE BEGINNING
SAFETY RECALL 07S57
SUBJECT
Safety Recall 07S57:
Certain 1997 - 2003 F-Super Duty, Excursion, and E-Series Vehicles Equipped with 7.3L Diesel Engines
Camshaft Position (CMP) Sensor Inspection / Replacement
Mar 30, 2010 at 4:38 PM
