2000 Ford F350 Clutch slave cylinder
2000 FORD F-350
105,000 MILES • V8 • 4WD • MANUAL
HANDYMANHUNTER
hello i was told in order to change the clutch slave cylinder i have to drop the transmission is this true
Dec 13, 2008 at 8:07 AM
DAVE H
  • 13,384 POSTS
CLUTCH SLAVE CYLINDER
Removal
Raise and support vehicle. Remove roll pin from hydraulic line. Disconnect hydraulic line from slave cylinder. Remove slave cylinder.
Inspection
Check clutch slave cylinder for leakage. Replace slave cylinder as necessary. Also, check slave cylinder for weak spring, worn or damaged piston and worn or damaged boot.
Installation
To install, reverse removal procedure. Bleed hydraulic system. See BLEEDING. Depress clutch pedal 10 times to fill clutch slave cylinder and to seat components.
Dec 13, 2008 at 8:13 AM
