my f-350 brakes are terrible this is second one i have owned the 1st one brakes were not that good this one is just bad i have purchaced it knowing it needed brake work it was in garage for 4 years with 27000 miles on it i first replaced the power steering pump as it needed it the pump fixed the steering problem but still can push the brakes almost to floor i then replaced 2 front calipers and replaced all rotors cross drilled and slotted all 4 and put hawk extreme duty pads all around brakes are just a lil better but still mushy and pedal still can push way down do you think the hydro boost could have something to do with this i shut the truck off pump brakes real hard like 5 times and hold then start it and the brake pedal goes to floor i have a 32ft enclosed race car trailer and i would not use this truck to pull it and that is the purpose of my truck any ideas
May 17, 2010 at 11:22 AM
