2000 Ford F350 brake pull
132,000 MILES • V8 • 4WD • AUTOMATIC
SHAGNASTY80
  • 7 POSTS
I have a truck that has been at the dealer for many repairs for one concern. When braking the vehicle pulls to the right. I have rotated the two front tires from side to side. nothing changed. I swapped resr rotors and pads from side to side. Nothing changed. Dekaer has replaced multiple suspension and steering components. This all started at 20k miles when the front brakes where done. Could it be a pad and rotr problem or an alignment issue.
Thanks in advance.
Jan 21, 2009 at 5:37 PM
  • 75,988 POSTS
BRAKES PULL TO ONE SIDE
Caused by contaminated linings, misadjusted brakes, a bad wheel cylinder or caliper, dragging brakes on one side or loose wheel bearings. Can also be caused by a mismatch of friction materials side-to-side on the front brakes or differences in rotor thickness, type or condition.
Jan 21, 2009 at 10:16 PM
