1999 Ford F350 STARTING
MACKPSJ
Engine Performance problem
1999 Ford F350 V8 Four Wheel Drive Automatic
ENGINE TURNS OVER BUT DOES NOT CRANK. HAS BEEN SITTING FOR A FEW MONTHS. WHAT DO YOU SUGGEST I DO FIRST? ALREADY TRIED STARTER FLUID.
Mar 10, 2009 at 1:33 PM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 10, 2009 at 6:59 PM
